Accord 03-08 lze vymětit org. autoradio?
Fórum: Interiér a Hi-Fi
3
  Strana 2 z 10
schizi je teď offline  schizi
PříspěvekZaslal: 19.10.2010 , 11:43   Citovat
Zvuk je parádní Úsměv Ikdyž mě stačí málo Velmi šťastný
No sundal jsem jen plasty, a ten konektor byl hned zespoda na radiu, takze zadne problemy nic... Instalace za 15min.
Příspěvky: 168 H+ body: 0 2003 Accord
pato poto je teď offline  pato poto
PříspěvekZaslal: 30.12.2010 , 3:07   Citovat
[quote="Ben"]Našel jsem to dělají to rusáci a dá se to objednat za 318 éček
a jak to ojednat? pa rusky nerozumim Smutný
Příspěvky: 16 H+ body: 0
PříspěvekZaslal: 30.12.2010 , 11:39   Citovat
kdyby mel nekdo zajem. Úsměv
Thanks for your inquiry about the Honda Accord car special DVD GPS TV radio bluetooth system device CAV-8070AD.
Price is USD536, and the device key function features as below:
2din all-in-one DVD player+7inch high definition digital Touch screen+Bluetooth+Amplifier+GPS+USB SD port+Radio+steering wheel control
Specially design for the Honda Accord 2003-2007 cars, perfect installation,no modification need, just need to plug and everything will fit and work.Connection of the standard is ISO type.
It is a plug and play version with original connector for Accord.
Do you need the following optional items?
Digital TV price is USD46. The parking sensors price USD29.
Accord car special camera price is USD32, and key function features as below:
High definition color CMOS camera with 170 degree view angle, night vision and waterproof
You can not buy the device in Czech,we will directly send the device to you from China.
Total express delivery cost is USD94 to Czech.
And express shipment time is four to six days from our factory directly reach your address.
We look forward to hearing from you soon.
Thanks and best regards.
Sincerely yours,
Andy Su
Website: tudy odkaz tudy odkaz
fun_thomas je teď offline  fun_thomas
PříspěvekZaslal: 4.1.2011 , 10:50   Citovat
schizi napsal:
Jaký plasty je potřeba sundat, abych se k tomu konektoru dostal?
Příspěvky: 269 H+ body: 0 2009 Civic Type-R
PříspěvekZaslal: 4.1.2011 , 10:57   Citovat
fun_thomas napsal:
Kdyby ses mrkl na predchozi stranku, tak tam ode me najdes odkaz s postupem i fotkami. Navic jsem ho daval snad jeste do dalsich 5 topicu, kdyz i ostatni meli potiz s pouzivanim vyhledavani Tak to valím bulvy
PříspěvekZaslal: 15.1.2011 , 18:56   Citovat
Tak nevím, jestli jsem blbej já, nebo se mi podařilo koupit nějakýho zmetka... pořídil jsem adaptér od Connects2
Montáž, zapojení do rádia, všechno v pohodě, ale po připojení USB flashky mi to MP3 na ní přehrává jak chce, vůbec nedodržuje adresářovou strukturu, skáče z písničky na písničku, některý MP3 nepřečte vůbec. Flashek jsem zkoušel víc, od velikosti 1GB po velikost 8GB, vždy naformátováno na FAT32 s dodrženou strukturou adresářů CD01, CD02 ...... CD06. Nenapadá někoho, kde by mohla být zrada?
EDIT: Přikládám screenshot struktury adresáře na flashce.
folder structure.jpg, 68.24 kB
Ben je teď offline  Ben
PříspěvekZaslal: 16.1.2011 , 20:06   Citovat
fun_thomas napsal:
Já jsem koupil tohle odkaz
a taky mi to nehrálo písničky podle čísel ve složce.Zjistil jsem že tam ty čísla ani nemusí být a hraje to v pořadí v jakém tam ty písničky nahraješ.Když kopíruješ víc skladeb naráz tak se ti nekopírují podle čísel skladeb.Nahrávej je do složky po jedné v pořadí v jakém je chceš mít. Mrk
Příspěvky: 110 H+ body: 4 2003 Accord Type-S
PříspěvekZaslal: 17.1.2011 , 21:43   Citovat
Tak vypadá že přesně to byl ten problém. Zkusil jsem tam ty MP3 nahrát jednu podruhé a opravdu to jede. Zdá se mi to celkem nelogický, ale hlavně že to jde aspoň nějak zprovoznit. Moc díky za pomoc a nakopnutí.
PříspěvekZaslal: 18.1.2011 , 9:40   Citovat
fun_thomas napsal:
Já jsem na to přišel když jsem sledoval v jakém pořadí to tam kopíruje když dáš kopírovat víc skladeb najednou.Tím pádem teď nemusíš ani číslovat skladby Mrk
Hondak je teď offline  Hondak
PříspěvekZaslal: 23.5.2011 , 9:15   Citovat
Zdravim chlapy, rozmyslam, ze by som chcel nieco poriesit s audiom ohladom mp3, takze moznost je cca 100 EUR XCARLINK, alebo nieco ako na odkazoch, nieco podobne ako pisal -TOYO- v teme Accord 7G.Nemate nahodou s niecim podobnym skusenosti niekto? Ci uz ten XCARLINK ako je s kvalitou zvuku propadne tie DVD radia.
Příspěvky: 236 H+ body: 0 2017 Civic
PříspěvekZaslal: 23.5.2011 , 17:42   Citovat
Hondak napsal:
Na kazde strance nahore mas policko hledat, najdes tu o Xcarlinku furu informaci. V zasade je z nej ale zvuk kvalitni a je limitovany daleko vic reproduktory v aute a kvalitou nahravky nez samotnym pristrojem. Xcarlink nas tu ma hodne nejenom v Acco 7G a nepostrehl jsem zatim zadnou negativni reakci.
Zkusenost s komplet vymenou OEM radia za levnou cinskou nahradu s milionem funkci tu nepopsal zatim nikdo, bud prvni je to dobrý
Ctirad je teď offline  Ctirad
PříspěvekZaslal: 6.11.2011 , 19:18   Citovat
Stejný problém jsem vyřešil nákupem adaptéru na tudy odkaz a můžu doporučit. Využívá konektoru rádia určeného pro CD měnič.
Chce to trochu trpětivosti a šikovnosti při zapojení konektoru do autorádia ( přes demontovanou schránku palubky), ale výsledek stojí za to. Převodník jsem umístil do schránky palubky na suchý zip. Umožňuje číst SD karty, USB i propojení linkovým vstupem z jakéhokoliv přehrávače nebo telefonu ( sluchátkový výstup).
Ovládá se prostřednictvím autoradia - jednotlivé vstupy se nabízí jako měnič CD. (AUX)
Příspěvky: 1 H+ body: 0
PříspěvekZaslal: 29.11.2011 , 13:58   Citovat
Tak jsem definitivně zavrhl origo radio s navigací a k ježíšku si koupil od soudruhů z Číny.A ejhle za cenu origo DVD s mapama od hondy mám rádio s navigací,DVD ,DVBT-TV,a couvací kamerou.Konečně mám z auta zase radost a nemusímk uč číst tu hlášku "DVD reading an arror" Velmi šťastný
SNC00532.jpg, 289.58 kB
SNC00528.jpg, 564.05 kB
SNC00552.jpg, 285.68 kB
SNC00553.jpg, 244.76 kB
Acxe je teď offline  Acxe
PříspěvekZaslal: 29.11.2011 , 17:53   Citovat
Vypadá to perfektně.. a co ovládání klimatizace atd.. vše funguje jak má? Jáká je kvalita zpracování a zvuk? Díky Úsměv OK
Příspěvky: 173 H+ body: 1 2004 Accord Type-S
PříspěvekZaslal: 29.11.2011 , 19:51   Citovat
jojo, taky mě zajímá to ovládání ventilace a klimy.. co sound systém,máš ho ...? případně funguje?
instalace proběhla dobře ? lícuje to tak jak má? pošli kdyžtak víc foto za světla Úsměv
Příspěvky: 370 H+ body: -1 2004 Civic Type-R
PříspěvekZaslal: 30.11.2011 , 12:25   Citovat
Ako som bol tento rok na autosalone v Nitre,tak tam vystavovali jeden tuningovy americky Accord a chlapik tam mal toto cinske radio,tak som sa ho vypytoval,ako je s tym spokojny a tak a hovoril,ze mu to sem zamrzne tak,ze musi ist odpojit baterku,co ma dost vystrasilo a zvukovo ze to nieje tiez nic moc,nehra to ani tak dobre ako original.Komunikacia ohladom reklamacie s cinanmi je strasne krkolomna,tak sa na to vybodol.Uz som bol tiez rozhodnuty,ze nieco take kupim,ale nakoniec som od toho po tychto skusenostiach upustil, i ked to mohol by ojedinely pripad.To ze to sem zamrzne by ma az tak netrapilo,ale ked to ma zvuk este horsi ako original,ktory nieje mimochodovom vobec zly,tak som povedal radsej nie. Smutný Vsak uvidis ty,mozno ty budes spokojny a bude to slapat v pohode.Hlavne napis ako sa Ti zda zvukovo oproti originalu,ale to je tiez dost subjektivna zalezistost.
alvi je teď offline  alvi
PříspěvekZaslal: 10.12.2011 , 22:46   Citovat
Ctirad napsal:
(AUX)
jaky acco mas ?
Příspěvky: 356 H+ body: 2 2006 Accord
PříspěvekZaslal: 10.12.2011 , 23:29   Citovat
Ben napsal:
no tak to je peckovice!!! OK OK OK
Tonny je teď offline  Tonny
PříspěvekZaslal: 19.12.2011 , 22:33   Citovat
Ben napsal:
práda tak hoď další foto ve dne ať vidíme jak to sedí a jak funguje? jsme napjatí!!! taky by se mi to líbilo. je to dobrý Je to tam.
Příspěvky: 113 H+ body: 0 2005 Accord Tourer
Dutch je teď offline  Dutch
PříspěvekZaslal: 19.12.2011 , 23:52   Citovat
Dekujeme Benovi přátele Jsem zvědav na info
Napadlo mě že kdyby tomu napsal větší info mohli bychom se po svátcích dohodnout a zjistit kolik by to stálo ve při větším odběru a udělat objednávku Se stydím
varuj je teď offline  varuj
PříspěvekZaslal: 20.12.2011 , 11:25   Citovat
K tej objednavke by som sa pripojil, uz som rozhodnuty dlhsiu dobu take nieco kupit. Len je ich viac druhov, ktory z nich je najlepsi? to mi hlava nebere Myslim tym, ktory bude mat zachovanych najviac povodnych funkcii origo autoradia (niektore napr. neukazuju nastavenu teplotu klimy, ...)
Příspěvky: 1506 H+ body: 4
Mar643 je teď offline  Mar643
PříspěvekZaslal: 20.12.2011 , 12:02   Citovat
ja sem nasel na ebay,vypada dobre tudy odkaz
Příspěvky: 5 H+ body: 0
PříspěvekZaslal: 20.12.2011 , 12:58   Citovat
varuj: no uvidíme jak na tom budeme po svátcích z penězi Velmi šťastný
ale máš pravdu , že to chce vybrat pokud možno za solidní prachy dobrou kavalitu a hlavně jak to bude s ovládáním z volantu? to taky funguje... to mi hlava nebere
Hondza je teď offline  Hondza
PříspěvekZaslal: 20.12.2011 , 13:20   Citovat
Taky to chci a tak jsem trochu pátral. Nejspíš se to vyrábí v Číně, takže bude lepší to objednat rovnou tam odkaz
Ovládání rádia z volantu ve všech odkazech co jsem našel píšou že funguje. Psal jsem Benovi a odpověděl mě, že je spokojen, akorát nefunguje venkovní teploměr na budíkách (dostává hodnotu od klimy přes sběrnici), ale venkovní teplota se ukazuje na displeji rádia a ten přídavný displej u modelů co měli origo navigaci. U naftových verzí (čili u mě) počítam ještě nebude fungovat přitápění klimou při studeným motoru, ale to jsem asi ochotnej akceptovat.
Jinak ví někdo jak to chodí na celnici? Jestli je nějaká možnost jak se tomu vyhnout HaHaaa , případně jak se rozhoduje do jaké kategorie cla se to zařadí, protože autorádio je 14 procent ale navigace je asi 3,7.
Příspěvky: 546 H+ body: 15 1992 Civic Vti
Verča je teď offline  Verča
PříspěvekZaslal: 20.12.2011 , 16:15   Citovat
Dutch napsal:
určitě bych se k objednávce připojila... OK
Příspěvky: 1915 H+ body: 0 2003 Accord Type-S
PříspěvekZaslal: 20.12.2011 , 16:22   Citovat
Komu z těch,kdo se připojí pak zbyde přebytečný CD měnič? Naši nechali Vojtu v autě zandavat CD,což by bylo v pohodě,kdyby tam nebylo víc CD,že... Takže teď mi CD zajede,chvíli to chroustá a pak to vyplivne CD a napíše error... Smutný Ne že bych CD v autě poslouchal,ale nemám rád,když něco nefunguje, jak má... Se stydím Takže pokud někdo vyhodí (nepoškrábané) originál rádio bez navigace s měničem,tak bych měl zájem... Se stydím
PříspěvekZaslal: 20.12.2011 , 16:44   Citovat
Hondza napsal:
zkusím to zjistit, znám člověka co objednává ve velkým různé věci z číny... přátele
EDIT: volal jsem mu z celkové částky za radia (balík) říkal že se počítá za obyč rádia 10% clo (říkal že třeba za DVD to je 13% což by se nás týkalo, ale říkal, že to je na celníkovi jak se vyspí a do jaké kategorie to přiřadí) a potom pokud to bude objednaný na fyzickou osobu tak se musí zaplatit DPH což je 20%. Takže celkem 30% z částky + doprava. Ble
PříspěvekZaslal: 25.12.2011 , 9:54   Citovat
kluci poraďte..
v acco s navi a changerem mi nejde vložit cd, ať mačkám load, nebo vlezu na displeji do changeru, zobrazí se mi jen těch 6 volných pozic, ale nic mi tam nejde dát. cd to prostě nevezme, do zdířky vložím skoro celé cd, ale motor ho nenabere.
nevíte co s tím ??
podotýkám, že mi navi nefuguje, jako vetšině.. Smutný
PříspěvekZaslal: 25.12.2011 , 23:57   Citovat
Johnie_Walker napsal:
kluci poraďte..
nevíte co s tím ??
V kazde volne pozici to musi sezrat CDcko i kdyz ho tam jenom trosku zasunes, nemusis ani mackat Load.
PříspěvekZaslal: 7.1.2012 , 14:10   Citovat
pánové, co ta objednávka? já jen, abych věděla na kdy a kolik si mám nachystat Úsměv
3
[ Čas: 0.2324s ][ Dotazy: 147 (0.0301s) ][ GZIP on - Debug on ]
